The Iconia One 7 is ready to travel the world. Its clean design was made to see and be seen. Its light, narrow case is easy to hold all day long. Its beautiful textured finish makes it easy to grab and go. It's always ready to capture and share your adventures.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Acer ICONIA ONE 7 B1-770-K06P - tablet - Android 5.0 (Lollipop) - 16 GB - 7" | Product Type | Tablet | Operating System | Android 5.0 (Lollipop) | Display | 7" IPS TFT - LED backlight - 1024 x 600 - Multi-Touch | Processor | MediaTek MT8127 (Quad-Core) | Processor Clock Speed | 1.3 GHz | Storage | 16 GB eMMC | RAM | 1 GB | Supported Flash Memory Cards | microSD, microSDHC | Wireless Connectivity | 802.11b/g/n, Bluetooth 4.0 | Rear Camera | 2 Megapixel | Front Camera | 0.3 Megapixel | Features | USB host | Battery Run Time | Up to 5.5 hours | Dimensions (WxDxH) | 10.88 cm x 0.95 cm x 18.9 cm | Weight | 280 g | Colour | White, blue | Image Colour Disclaimer | The displayed product image may be a different colour | Localisation | United Kingdom |
General | |
Display | |
Type | 7" IPS TFT - LED backlight |
Resolution | 1024 x 600 |
Touchscreen | Multi-Touch |
Features | Glare, CineCrystal, Mercury free, Wide Viewing Angle |
Processor | |
Processor | MediaTek MT8127 |
Number of Cores | Quad-Core |
Memory | |
RAM | 1 GB - DDR3L SDRAM |
Max Supported Capacity | 32 GB |
Communications | |
Rear Camera | |
Sensor Resolution | 2 Megapixel |
Still Image Resolutions | 640 x 480, 1600 x 1200 |
Front Camera | |
Sensor Resolution | 0.3 Megapixel |
Multimedia | |
Audio | Microphone, speaker |
Expansion and Connectivity | |
Expansion Slots | 1 x microSD |
Interfaces | 1 x Micro-USB , 1 x headphones |
USB Host | Yes |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Battery | |
Technology | Lithium polymer |
Capacity | 2780 mAh |
Run Time Details | Video playback: up to 5.5 hours |
Miscellaneous | |
Sensors | G-sensor |
Features | Volume control |
Included Accessories | Power adapter |
Compliant Standards | RoHS, WEEE |
Dimensions & Weight | |
Width | 10.88 cm |
Depth | 0.95 cm |
Height | 18.9 cm |
Weight | 280 g |
