Acer Extensa EM2 series is built around companies' demands for reliable, easy to manage, expandable and thoroughly secure machines with a cost-effective design.
Product Description | Acer Extensa M2710_E - MT - Core i5 6400 2.7 GHz - 8 GB - HDD 1 TB | Type | Personal computer - mini tower | Localisation | Region: United Kingdom | Processor | Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 8 GB (installed) / 16 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | HDD 1 TB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD-Writer | Graphics Controller | Intel HD Graphics 530 | Networking | 1GbE | Power | AC 120/230 V | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 17.5 cm x 37.2 cm x 36.5 cm | Weight | 6 kg |
General | |
Type | Personal computer |
Product Form Factor | Mini tower |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6400 |
Clock Speed | 2.7 GHz |
Max Turbo Speed | 3.3 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel H110 Express |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 8 GB / 16 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Features | Unbuffered |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 530 |
Video Interfaces | VGA, DVI |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111E |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Bays | 5.25" , 3.5" |
Slots | DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 PCIe x16 , 1 PCIe x1 , 1 M.2 Card |
Interfaces | 4 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Compliant Standards | BSMI, CB, FCC, RoHS, PC 2001, EuP |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V |
Power Provided | 220 Watt |
Efficiency | 82%+ |
Power Factor Correction | Yes (active) |
Operating System / Software | |
Dimensions & Weight | |
Width | 17.5 cm |
Depth | 37.2 cm |
Height | 36.5 cm |
Weight | 6 kg |
