BlueLightShield technology reduces the exposure of blue light, which can be potentially harmful, by adjusting color hue and brightness. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand. Flickerless technology eliminates screen flickering by providing a stable supply of power to the display. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
Product Description | Acer ED242QRwi - LED monitor - curved - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Energy Class | Class F | Energy Consumption per Year | 40 kWh | Power Consumption (On mode) | 27 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.27156 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 84% | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | White | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ComfyView, Flicker-Less technology, Wide Viewing Angle, Acer BluelightShield technology, Ultra Low Blue Light technology, Ultra-Low Blue Light Technology |
Colour | White |
Connectivity | |
Interfaces | HDMI , VGA |
Mechanical | |
Tilt Angle | -5/+20 |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Power Consumption SDR (On mode) | 23 kWh/1000h |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
