Continually updated, the Acer C7 Chromebook keeps getting better and better. It starts in seconds, has virus protection built in, and runs your favorite Google apps plus thousands more. At about an inch thin and light, this Chromebook goes wherever you go and keeps your files safe and secure in the cloud.
Product Description | Acer Chromebook 11 C730-C8T7 - 11.6" - Intel Celeron - N2840 - 2 GB RAM - 16 GB SSD - UK | Product Type | Chromebook | Operating System | Chrome OS | Processor | Intel Celeron N2840 / 2.16 GHz, up to 2.58 GHz / 1 MB Cache | Memory | 2 GB DDR3L (provided memory is soldered) | Storage | 16 GB SSD | Display | 11.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics | Keyboard | UK | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac | Battery | 3-cell | Colour | Grey | Dimensions (WxDxH) | 30.26 cm x 20.66 cm x 2.175 cm | Weight | 1.4 kg | Localisation | Region: United Kingdom |
General | |
Operating System | Google Chrome OS |
Processor / Chipset | |
CPU | Intel Celeron N2840 / 2.16 GHz |
Max Turbo Speed | 2.58 GHz |
Number of Cores | Dual-Core |
Cache | L2 - 1 MB |
64-bit Computing | Yes |
Features | Intel Burst Technology |
Memory | |
RAM | 2 GB (provided memory is soldered) |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Storage | |
Main Storage | 16 GB SSD |
Display | |
Type | 11.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Camera | Yes - HD |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Battery | |
Technology | 3-cell |
Capacity | 3220 mAh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces | HDMI , Headphone/microphone combo jack , 2 x USB 2.0 |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Grey |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.4 kg |
