The Acer CB Series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
Product Description | Acer CB281HK - LED monitor - 28" | Device Type | LED-backlit LCD monitor - 28" | Energy Class | Class C | Energy Consumption per Year | 75 kWh | Power Consumption (On mode) | 51 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI/MHL: 60 Hz, DVI: 30 Hz) | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 1.07 billion colours | Input Connectors | DVI-D, DisplayPort, HDMI (MHL) | Display Position Adjustments | Height, pivot (rotation) | Voltage | AC 100 - 240 V | Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 28" |
Panel Type | TN |
Backlight Technology | LED backlight |
Features | HDCP, Acer Adaptive Contrast Management (ACM) |
Colour | Black |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | DVI-D (dual link) (HDCP) , MHL / HDMI , DisplayPort , Audio line-out |
Mechanical | |
Miscellaneous | |
Cables Included | 1 x DVI cable , 1 x DisplayPort cable |
Power | |
Input Voltage | AC 100 - 240 V |
On / Off Switch | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
