ITEM | QTY | PRICE |
Epson EB-680 XGA 3LCD 3500 Lumens Pro...
3 | £4,232.91 |
Acer's BE0 monitors offer a class-leading combination of ultra-high resolution screens, superb color definition, EyeProtect technologies, and a 4-side borderless zeroframe design so you can work comfortably all day.
Product Description | Acer BE270U - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class A | Energy Consumption per Year | 43 kWh | Power Consumption (On mode) | 30 W | Features | USB 3.1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 2560 x 1440 at 75 Hz | Brightness | 350 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 6 ms | Colour Support | 16.7 million colours | Colour Gamut | 100% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Weight | 6.25 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Directive 1275/2008, EN 50564:2011, EN55022:2010/AC:2011 Class B, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN 61000-3-3:2013, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.1 hub |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour | Black |
Weight | 6.25 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | HDMI , DisplayPort , Audio line-out , 4 x USB 3.1 downstream , USB 3.1 upstream , USB-C |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 120 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable , 1 x USB-C cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 490 mW |
Power Consumption (Off Mode) | 450 mW |
Sustainability Information | |
ENERGY STAR Certified | Yes |
