Ideal for use in office environments, libraries and computer labs, Professional series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Product Description | Acer B276HULCbmiidprzx - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 58 kWh | Power Consumption (On mode) | 40 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 2560 x 1440 at 60 Hz | Brightness | 350 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 6 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, DVI-D, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Dark grey | Dimensions (WxDxH) - with stand | 63.97 cm x 24.71 cm x 40.66 cm | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 3-year warranty | Designed For | TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N; TravelMate X3 TMX3410-M-52M7; X5 TMX514-51-560Q, TMX514-51T-54EG |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ErgoStand, HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Mercury free, Acer eColor technology, 8-bit gamma |
Dimensions (WxDxH) | 63.97 cm x 24.71 cm x 40.66 cm - with stand |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DVI-D (dual link) (HDCP) , DisplayPort , DisplayPort output , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 120 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
Miscellaneous | |
Features | Integrated cable management, portrait / landscape mode, VESA interface support, USB 3.0 port power off USB charging |
Cables Included | 1 x DVI cable , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 32.1 kWh/1000h |
Power Consumption Stand by | 0.36 Watt |
Power Consumption (Off Mode) | 0.25 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 63.97 cm - depth: 24.71 cm - height: 40.66 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Compatibility Information | |
Designed For | Acer TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N , Acer TravelMate X3 TMX3410-M-52M7 , Acer TravelMate X5 TMX514-51-560Q, TMX514-51T-54EG |
