Combine robust metal cover and great essentials, and you get attractive powerhouses built for everyday computing.
Product Description | Acer Aspire F 15 F5-573G-5996 - 15.6" - Intel Core i5 - 6200U - 8 GB RAM - 128 GB SSD + 1 TB HDD - UK | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 128 GB SSD + 1 TB HDD / 5400 rpm | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA GeForce GTX 950M | Video Memory | 4 GB GDDR5 SDRAM | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 6-cell | Colour | Obsidian black | Dimensions (WxDxH) | 38.16 cm x 25.9 cm x 2.845 cm | Weight | 2.4 kg | Localisation | Region: United Kingdom |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD |
Secondary Storage | 1 TB HDD SATA 3Gb/s / 5400 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM - tray |
Display | |
Type | 15.6" - TN |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | HDCP, anti-glare |
Audio & Video | |
Graphics Processor | NVIDIA GeForce GTX 950M |
Camera | Yes - 1280 x 720 |
Camera Features | HDR (High Dynamic Range), 720p HD movie recording |
Sound | Stereo speakers, microphone |
Audio Features | Output: Acer TrueHarmony Plus technology |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard |
Communications | |
Wireless | Bluetooth, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 3165 - M.2 Card |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 2800 mAh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 90 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | USB 2.0 , HDMI , USB 3.0 , LAN , USB-C , Headphone/microphone combo jack , USB 3.0 (with power off charging) |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Case Material | Anodised aluminium |
Features | Wake on LAN, MU-MIMO technology, Acer BluelightShield technology |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2.4 kg |
Sustainability Information | |
TCO Certified | - |
