Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. The E laptop allows you to do a touch more and travel a touch further. Acer's precision touchpad and chiclet keyboard are designed specifically to improve accuracy and speed.
Product Description | Acer Aspire ES 15 ES1-522-88WC - 15.6" - AMD A8 - 7410 - 8 GB RAM - 1 TB HDD - UK | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | AMD A8 7410 / 2.2 GHz, up to 2.5 GHz / 2 MB Cache | Memory | 8 GB DDR3L (1 x 8 GB) | Storage | 1 TB HDD / 5400 rpm | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | AMD Radeon R5 | Keyboard | UK | Integrated Webcam | Yes | Networking | Bluetooth, 802.11b/g/n, Gigabit Ethernet | Battery | 3-cell | Colour | Black | Dimensions (WxDxH) | 38.16 cm x 25.8 cm x 2.715 cm | Weight | 2.4 kg | Localisation | Region: United Kingdom | Environmental Standards | - EPEAT Climate+ |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | AMD A8 7410 / 2.2 GHz |
Max Turbo Speed | 2.5 GHz |
Number of Cores | Quad-Core |
Cache | L2 - 2 MB |
64-bit Computing | Yes |
Features | AMD Turbo CORE technology |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 1 TB HDD SATA / 5400 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM - tray |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | AMD Radeon R5 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - VGA |
Resolution | 0.3 Megapixel |
Sound | Microphone |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Communications | |
Wireless | Bluetooth, 802.11b/g/n |
Wireless Controller | Atheros WB335 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 3500 mAh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | 2 x USB 2.0 , USB 3.0 , HDMI , LAN , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Black |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2.4 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
