The NETGEAR Universal WiFi Range Extender effectively doubles the operating distance of your entire wireless network and conveniently avoids additional need for power cables or device clutter on your office desk or home theater. WN3000RP extends your wireless network to include the area outside the range of your existing wireless router by overcoming obstacles and enhancing overall network signal quality, giving you the freedom to roam anywhere in the house and access Internet without worrying about coverage. The product was specifically designed to be plugged into an electrical outlet, and blends in nicely with any surrounding. It is compatible with wireless b/g/n routers, gateways and Internet service provider devices.
Product Description | NETGEAR WN3000RP Universal WiFi Range Extender - Wi-Fi range extender - Wi-Fi | Device Type | Wi-Fi range extender | Form Factor | External | Localisation | United Kingdom | Data Link Protocol | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Frequency Band | 2.4 GHz | OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7 | Dimensions (WxDxH) | 11.2 cm x 7.4 cm x 4.5 cm | Weight | 245 g |
General | |
Width | 11.2 cm |
Depth | 7.4 cm |
Height | 4.5 cm |
Weight | 245 g |
Networking | |
Connectivity Technology | Wireless |
Features | Repeating mode, Wi-Fi Protected Setup (WPS), wireless bridge mode, Push ‘N’ Connect button |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup |
Aerial | |
Antenna | External detachable |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Miscellaneous | |
Compliant Standards | RoHS, WEEE, CEC |
Power | |
Power Device | Internal power supply |
Software / System Requirements | |
