TP LINK Deco M4 Whole Home WiFi System - 2 Pack
2 Pack
£74.98
15 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Deco M4 provides fast and stable connections with speeds of up to 1167 Mbps and works with major internet service provider (ISP) and modem
  • Deco can handle traffic from even the busiest of networks, providing lag-free connections for up to 100 devices
  • Parental Controls limits online time and block inappropriate websites according to unique profiles created for each family member
  • Setup is easier than ever with the Deco app there to walk you through every step
  • Type: Wi-Fi system
  • Connectivity: Wired, Wireless
  • Speed: 867Mbps, < 1000 Mbps
  • Protocol: 802.11n, 802.11g, Wired Ethernet, 802.11ac + 10 more
  • Compatibility: Android, Apple iOS
Product codes
chevron icon
chevron icon
Deco uses a system of units to achieve seamless whole-home Wi-Fi coverage - eliminate weak signal areas once and for all! With advanced Deco Mesh Technology, units work together to form a unified network with a single network name. Devices automatically switch between Decos as you move through your home for the fastest possible speeds.
A Deco M4 two-pack delivers Wi-Fi to an area of up to 2,800 square feet. And if that's not enough, simply add more Decos to the network anytime to increase coverage.
Deco uses a system of units to achieve seamless whole-home Wi-Fi coverage — eliminate weak signal areas once and for all
A Deco M4 two-pack delivers Wi-Fi to an area of up to 2,800 square feet. And if that’s not enough, simply add more Decos to the network anytime to increase coverage.
Deco M4 provides fast and stable connections with speeds of up to 1167 Mbps and works with major internet service provider (ISP) and modem.
Parental Controls limits online time and block inappropriate websites according to unique profiles created for each family member.
Setup is easier than ever with the Deco app there to walk you through every step.
2-in-1 Router and Access Point Modes
Flexible and multifunctional, the Deco M4 includes a variety of features allowing it to serve as a router or access point. Just choose the mode for your actual network demands and experience the maximum wireless flexibility.
Engineered for More Devices
Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance
Seamless Roaming with One Wi-Fi Name
TP-Link Mesh means Deco units work together to form one unified network. Your phone or tablet automatically connects to the fastest Deco as you move through your home, creating a truly seamless Wi-Fi experience.
Experience Wi-Fi Like Never Before
Deco M4 uses TP-Link Mesh technology to cover your entire home in powerful Wi-Fi. Multiple units seamlessly work together to create a home network like nothing you’ve ever experienced.
chevron icon
Product Description TP-Link DECO M4 - Wi-Fi system - Wi-Fi 5 - desktop
Device Type Wi-Fi system - mesh
Enclosure Type Desktop
Wi-Fi System Components 2 routers
Wi-Fi System Coverage Up to 2,800 sq.ft
WAN Ports Qty 2
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 867 Mbps
Network / Transport Protocol PPTP, L2TP, PPPoE
Routing Protocol Static IP routing
Features IPv6 support, parental control, Access Point operational mode, firmware upgradable, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, DHCP client, MU-MIMO technology, beamforming technology, router mode
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Dimensions (WxDxH) 9.07 cm x 9.07 cm x 19 cm
Weight 730 g
System Requirements Android 4.3 or later, Apple iOS 9 or later
chevron icon
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: H3X5 048625
£81.62
product
Ref: H3X5 048423
£42.62
product
Customer return - item has been used and shows signs of use
Ref: H3X5 048584
£59.86
product
Ref: H3X5 048625
Accessories
Packaging
Functional
Software
Manuals
£81.62
product
Ref: H3X5 048423
Accessories
Packaging
Functional
Software
Manuals
£42.62
product
Ref: H3X5 048584
Accessories
Packaging
Functional
Software
Manuals
£59.86
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£74.98
