The NETGEAR Universal Dual Band Wi-Fi Range Extender - Wall-plug Edition, simultaneously extends Wi-Fi coverage of an existing Wi-Fi network throughout your home so you can get better coverage for your Wi-Fi devices - on your patio or even in the backyard. The Wi-Fi Extender supports simultaneous dual band Wi-Fi coverage so you can connect devices on both 2.4 GHz and 5 GHz bands. While providing better Wi-Fi coverage, the Wi-Fi Extender also allows you to play music wirelessly over your network through any stereo or speaker in your home. By plugging in a USB printer into the USB port on the Wi-Fi Extender, you can make any wired USB printer accessible wirelessly from any Wi-Fi device and any room in your home.
Product Description | NETGEAR WN3500RP - Wi-Fi range extender - Wi-Fi | Device Type | Wi-Fi range extender | Form Factor | External | Localisation | United Kingdom | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n | Frequency Band | 2.4 GHz, 5 GHz | Included Accessories | Docking station | OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7 | Dimensions (WxDxH) | 12 cm x 7.9 cm x 4.2 cm | Weight | 238 g |
General | |
Width | 12 cm |
Depth | 7.9 cm |
Height | 4.2 cm |
Weight | 238 g |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 300 Mbps |
Status Indicators | Power, status, WPS |
Features | Auto-sensing per device, print server, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button, FastLane Technology |
Encryption Algorithm | WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 , 1 x USB 2.0 - Type A , 1 x audio |
Miscellaneous | |
Compliant Standards | RoHS, WEEE, CEC |
Power | |
Power Device | Internal power supply |
Software / System Requirements | |
