Click to visit BT.com
BT Studio 3100 Twin Cordless Handsets
BT Studio 3100 Twin Cordless Handsets Image for illustration only
BT BT Studio 3100 Twin Cordless Handsets
In stock now
Quicklinx: 4LPMG6
Mfr#: 034589
Multiple handsets available
£34.99 inc vat
50 Name and number directory
  • Your handset can store up to 50 of your most frequently used names and numbers.
    Caller Display with up to 40 number calls list1
  • See who is calling you before you answer the phone. The calls list holds details of your last 40 callers, including the phone number and time and date of the call. If a number matches a stored phonebook entry, the caller's name is displayed alternately with the number.
    Call Waiting1
  • With Call Waiting, if you are on a call and another call comes in, you hear a soft beep in the earpiece. When used with Caller Display you can see who is calling whilst engaged on another call providing the number of the caller is not withheld.
    Secrecy
  • Whilst on a call, use the secrecy feature to talk to someone else in the room without your caller hearing you.
    10 Last number redial
  • Easily redial any of the last 10 numbers called from the redial list.
    Choice of base and handset ringer melodies
  • There are 5 different ringer melodies for the base and 5 for the handset so you can personalise your BT Studio 3100.
  • There are also 5 ringer volume control levels so you can set the ringer at a volume to suit you or you can switch it off altogether.
Telephone Features
  • 50 Name and number phonebook
  • Assign melodies to specific phonebook entries 1
  • Caller Display with up to 40 number calls list 1
  • CallWaiting 1
  • 10 Last number redial
  • Secrecy facility
  • Call timer
  • Clock and alarm
  • Preparatory dialling
  • Earpiece volume control
  • Base station and handset ringer volume control
  • Choice of 5 handset ringer melodies
  • Choice of 5 base ringermelodies
  • Display language options
  • Handset power on / off
  • Handset naming feature
  • Keypad lock
  • Key beeps on/off
  • Paging
  • Talktime up to 10 hours, 30 minutes / standby time up to 160 hours2
  • Range of up to 300 metres outdoors/50metresindoors3
  • Autotalk / standby
  • Battery low warning
  • Out of range warning
  • Switchboard compatible
  • Tone and pulse dialling
  • Recall
  • Dialling pause
Features with more than one handset
  • GAP compatible - register a maximum of 5 handsets to one base and one handset can be registered to up to 4 bases
  • Internal handset to handset calls
  • Call transfer between handsets
  • 3Way calling
This pack contains
  • 2 BT Studio 3100 base
  • 2 BT Studio 3000 handset
  • 4 NiMH AAA rechargeable batteries
  • 2 mains power adaptor
  • One telephone line cord
  • User guide
1 You must subscribe to a Caller Display or Call Waiting Service for these features to work. A quarterly fee may be payable. 2 When batteries are fully charged. 3 In ideal conditions.
Where described as VoIP compatible, this applies when used with the appropriate VoIP service such as BT's Broadband Talk service and hardware such as the BT Home Hub - it is not a standalone voip phone
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the BT Studio 3100 Twin Cordless Handsets
BT Studio 3100 Twin - cordless phone w/ call waiting caller ID
Cordless phone w/ call waiting caller ID + 1 additional handset(s)
Cordless Phone Standard
DECT\GAP
Intercom
Built-in
Caller ID
Built-in
Display
LCD display - monochrome
Additional Handsets Qty
1
Phone Features
DECT\GAP
Max Handsets Supported
5
Max Base Units Supported
4
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Type
Keypad
Dialer Location
Handset
Dialing Modes
Pulse, tone
Conference Call Capability
3-way
Intercom
Built-in
Caller ID
Built-in
Call Waiting
Built-in
Call Transfer
Built-in
Menu Operation
Built-in
Function Buttons
Recall button, memory pause button, mute button
Volume Control
Ringer Control
Handset Locator
Built-in
Additional Functions
Call timer, built-in clock, Alarm
Additional Features
Autotalk, out of range alert, key lock
Phone Memory
Phone Directory Capacity
50 names & numbers
Dialed Calls Memory
10
Caller ID Memory
40 names & numbers
Display
Display Location
Handset
Aerial
Internal
Phone charging stand + power adaptor - external
Rechargeable
Talk Time
Up to 630 min
Standby Time
Up to 160 h
Audible Battery Alert
Built-in
Accessories
1 - 3 products displayed out of 3
  product description   In stock inc vat qty
  BT ADSL Micro Filter RS BT ADSL Micro Filter RS
quicklinx: 4D46G6 | Mfr#: 011249
In stock now £10.23
  Durable 5758 Telephone Cleaning Wipes - Box of 100 Durable 5758 Telephone Cleaning Wipes - Box of 100
quicklinx: 4GWTG6 | Mfr#: 5758
In stock now £2.57
  Belkin 1-Way MasterCube with Tel / Fax / Modem Protection Belkin 1-Way MasterCube with Tel / Fax / Modem Protection
quicklinx: 2D4BG6 | Mfr#: F9H110VUKCW
2.0*
In stock now £6.85
feature value
Type Cordless phone
Answer Machine No
Handsets Included 2
Brand BT
Stock Status In Stock
Price Range Inc VAT 0 - 50
