BT.com
Wishlist
ZyXEL XS1920-12 Switch 12 Ports Managed Rack-Mountable
ZyXEL XS1920-12 Switch 12 Ports...
£852.91
Hurry, only 3 left in stock!
£852.91
Add to wishlist
Delivery
Standard 1-3 working days
In today's rapidly changing world of cloud-based products and services, it can be difficult for large enterprises, as well as small and medium-sized businesses (SMBs) to decide how to best handle increased data and the demands of applications like VoIP, video streaming and IP surveillance. In this environment, networks need to be simultaneously faster and more reliable, as well as easy to set up and maintain. To help meet these challenges, ZyXEL has introduced the XS1920-12, a 10GbE smart switch for SMB that economically upgrades any network to high-speed 10GbE bandwidth.
ZyXEL XS1920-12 - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
10 x 10GBase-T + 2 x combo 10 Gigabit SFP+
Performance
Switching capacity: 240 Gbps , Forwarding performance: 178.6 Mpps
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, CLI
Flow control, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, NTP server, IP-MAC binding, SNMP trap, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), Dynamic VLAN Support (GVRP), dual firmware images, Strict Priority Queuing (SPQ), Neighbor Discovery Protocol (NDP), 2MB packet buffer, loop prevention, port isolation, Class of Service (CoS), tagged VLAN, IGMP proxy, ErrDisable Recovery, ZyXEL One Network (ZON), IGMP filtering, IGMP throttling, CPU protection, IP source guard, ARP inspection, policy based rate limiting
IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
44 cm x 33 cm x 4.45 cm
4.205 kg
Bundled Services
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
Status Indicators
Link activity, power, system
12 x 10GBase-T - RJ-45 , 2 x 10GBase-X - SFP+
Internal power supply
95.6 Watt
Rack Mounting Kit
Included
MTBF
839,624.71 hours
BSMI, RoHS, FCC Part 15 A, LVD, EMC Class A, BSMI ENC
44 cm
33 cm
4.45 cm
4.205 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£4.95
£3.79
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.34
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.82
Scroll to top
