BT.com
Wishlist
Zyxel XGS4700-48F L3 Managed 10G Stackable Switch
Zyxel XGS4700-48F L3 Managed 10G...
£3,520.11
£3,520.11
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL XGS series of L3 switches enable enterprise and SMB businesses to deploy high availability networks to meet the need to migrate to a virtualized and consolidated solution.
The XGS4700 series delivers not only robust, reliable enterprise-class L2/L3 switch features but is also designed to accomplish high-availability routing for better utilization of network bandwidth.
ZyXEL XGS-4700-48F - switch - 48 ports - Managed - desktop
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
48 x SFP
Performance
Switching capacity: 192 Gbps , Forwarding performance: 143 Mpps
Host table entries (IPv4): 8000 , Routing table entries: 12000 , Routing domains: 128
MAC Address Table Size
32K entries
Routing Protocol
OSPF, RIP, RIP-2, IGMPv2, IGMP, DVMRP, VRRP, IGMPv3, static IPv4 routing, static IPv6 routing, ECMP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, routing, Layer 3 switching, Layer 2 switching, auto-negotiation, trunking, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Weighted Fair Queuing (WFQ), Digital Diagnostics Monitoring Interface (DDMI), ZyXEL iStacking Technology, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, priority-based flow control, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, bandwidth control, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, Traffic Control, DHCP client, Multicast VLAN Registration (MVR)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ag, IEEE 802.1ab (LLDP)
AC 120/230 V / DC -36 -72 V ( 50/60 Hz )
Power Redundancy
Optional
44 cm x 42.4 cm x 4.5 cm
5.4 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
48 x SFP
Performance
32K entries
Routing Protocol
Encryption Algorithm
SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
2 MB
Status Indicators
Port status, link activity, power, system, alarm
48 x SFP (mini-GBIC) , 1 x RJ-45 - management , 1 x serial (RS-232) - DB-9 - management , 1 x alarm - terminal block
Expansion Slots
2 (total) / 2 (free) x Expansion Slot
Internal power supply
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
EMC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1
44 cm
42.4 cm
4.5 cm
5.4 kg
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£5.17
£3.90
£12.74
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.12
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.70
£19.78
£25.15
£57.14
Scroll to top
