BT.com
Wishlist
Zyxel XGS3700-24HPL2/3 24 port PoE+Gigabit Switch with uplinks
Zyxel XGS3700-24HPL2/3 24 port...
£1,573.76
Hurry, only 1 left in stock!
£1,573.76
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL XGS3700 series are advanced layer 2 plus Gigabit managed switches perfect for data center access, SMB core/aggregation, and mission critical PoE applications. The series consists of eight (8) models including 24 port configurations, PoE and non-PoE models, as well as 10GbE uplink options. The complete series is designed with an advanced feature set with static routing, policy-based routing (PBR), VRRP and ECMP support. The high redundancy hardware architecture includes dual, internal power supplies and hot-swappable fan and power modules. The PoE models also comply with the IEEE 802.3at PoE Plus standard and provide industry-leading PoE power budget of up to 1000 watts.
Zyxel XGS3700-24HP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
460 W
Performance
Switching capacity: 128 Gbps , Forwarding performance: 95 Mpps
Routing table entries: 512 , Routing domains: 128
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, VRRP, static IP routing, IGMPv3, ECMP, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, ARP support, trunking, IGMP snooping, Syslog support, traffic shaping, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, VLAN Stacking, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, RADIUS support, DHCP server, MLD snooping, bandwidth control, Equal-Cost Multipath (ECMP), LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), NTP server, IP-MAC binding, DHCP client, Management Information Base (MIB), Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), 2MB packet buffer, loop prevention, port isolation, hot swappable fan, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), IGMP proxy
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3aq, IEEE 802.3at, IEEE 802.3az
Power Redundancy
Optional
44 cm x 43.7 cm x 4 cm
7.55 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
460 W
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
24 x 1000Base-T - RJ-45 - PoE+ - 30 W , 4 x SFP+ , 1 x console - 9 pin D-Sub (DB-9) , 1 x RJ-45 - management
Internal power supply
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
600 Watt
MTBF
220,000 hours
BSMI, RoHS, FCC Part 15 B Class A, LVD, EMC Class A
44 cm
43.7 cm
4 cm
7.55 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
Accessories
£4.95
£3.82
£11.95
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.53
£54.15
Scroll to top
