BT.com
Wishlist
Zyxel XGS3600-26 24-Port L2 Metro Switch
Zyxel XGS3600-26 24-Port L2 Metro...
£913.28
Hurry, only 1 left in stock!
£913.28
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL XGS3600 series is Telco-class layer 2 carrier Ethernet switches ideal for Ethernet service aggregation and extension. The series is an excellent solution that provides an ideal combination of affordability with capabilities for carrier access networking.
The ZyXEL XGS3600 series L2 GbE switches offer wire-speed flow control that classifies and prioritizes the incoming packets according to the predefine QoS policies that meet requirements of service providers. In terms of classification, the Differentiated Services Code Point (DSCP) field and the 802.1p Class of Service (CoS) field is identified to assess the priority of incoming packets. Classification and reclassification can be based on criteria as specific as rules based on IP, MAC addresses, VLAN ID or TCP/ UDP port number. For bandwidth management, the XGS3600 series provides 8 priority queues per port for different types of traffics, allowing service providers to set policy-based rate limitations that take full advantage of constrained network resources and guarantee the best performance.
ZyXEL XGS3600-26F - switch - 26 ports - Managed - desktop, rack-mountable
Switch - 26 ports - Managed
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
20 x Gigabit SFP + 4 x combo Fast Ethernet/Gigabit SFP + 2 x 10 Gigabit SFP+
Performance
Switching capacity: 88 Gbps , Forwarding performance: 65.47 Mpps
MAC Address Table Size
32K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, SSH-2, CLI
Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, IPv6 support, firmware upgradable, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, temperature sensor, Cable Diagnostics Function, bandwidth control, IPv4 support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), TFTP server, IP-MAC binding, SNMP trap, DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), IGMP proxy, 4MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az, ITU-T Y.1731, ITU-T G.8031, ITU-T G.8032
AC 120/230 V / DC 48 V ( 50/60 Hz )
44.2 cm x 21.12 cm x 4.4 cm
3.1 kg
United Kingdom
Enclosure Type
Subtype
Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x MIPS : 400 MHz
RAM
128 MB - DDR2 SDRAM
Flash Memory
32 MB
Status Indicators
Port status, power, system, alarm
24 x 10Base-T/100Base-TX/1000Base-T - SFP (mini-GBIC) , 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x serial (RS-232) - DB-9 , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 - management , 2 x 10GBase-SR/10GBase-LR - SFP+
Internal power supply
55 Watt
United Kingdom
44.2 cm
21.12 cm
4.4 cm
3.1 kg
65 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£5.17
£3.90
£12.74
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.12
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.70
£57.14
Scroll to top
