BT.com
Wishlist
Zyxel XGS1910-24 24 port Gigabit Smart Managed Switch w 10G uplink
Zyxel XGS1910-24 24 port Gigabit...
£494.32
£494.32
Add to wishlist
Delivery
Standard Due date unavailable
The XGS1910 series is ideal for securing 10/100, Gigabit and 10 GbE connectivity; it also offers IEEE 802.3az, access security, advanced prioritization, traffic-monitoring capabilities and a fanless design. Meanwhile, the series supports smooth IPv6 migration for future expansions. As a result, the XGS1910 series is suitable for fulfilling SMB network needs with cost-effective, valuable frameworks.
ZyXEL XGS1910-24 - switch - 24 ports - Managed - desktop
Switch - 24 ports - Managed - stackable
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
20 x 10/100/1000 + 4 x combo Gigabit SFP + 2 x 10 Gigabit SFP+
Performance
Non-blocking switching capacity: 88 Gbps , Forwarding performance: 65.5 Mpps
MAC Address Table Size
32K entries
Remote Management Protocol
RMON 1, RMON 2, SNMP, RMON 3, RMON 9, HTTP
Flow control, auto-negotiation, ARP support, trunking, VLAN support, packet filtering, store and forward, MAC address filtering, IPv6 support, IP address filtering, half duplex mode, full duplex mode, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, bandwidth control, LACP support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), IP-MAC binding, DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, loop prevention, port isolation, congestion control
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az, UPnP
AC 120/230 V ( 50/60 Hz )
43 cm x 18 cm x 4.4 cm
2.1 kg
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
32K entries
Max Units In A Stack
8
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
RAM
4 MB
Status Indicators
Power, system, alarm, link/activity
24 x 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 4 x SFP (mini-GBIC) , 1 x console - DB-9 , 2 x SFP+
Internal power supply
32 Watt
FCC, RoHS, BSMI CNS 13438, ICES, BSMI CNS 14336, LVD
United Kingdom
43 cm
18 cm
4.4 cm
2.1 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
