BT.com
Wishlist
Zyxel WRE2206 Wireless N300 Range Extender
Zyxel WRE2206 Wireless N300 Range...
£25.44
More than 50 in stock
£25.44
Add to wishlist
Delivery
Standard 3-5 working days
ZyXEL WRE2206 Wireless N300 Range Extender is to extend your home wireless (Wi-Fi) network to those areas with unreliable signal. The WRE2206 is optimized for the best Wi-Fi experience and delivers up to 30% better coverage than ordinary Wi-Fi extenders with its power amplified antennas. The one-touch WPS button makes it simple to extend your existing Wi-Fi network, while the LED indicator helps you find the best location for the extender.
ZyXEL WRE2206 - Wi-Fi range extender
External
United Kingdom
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
AC 120/230 V ( 50/60 Hz )
5.5 cm x 8.3 cm x 7.8 cm
68 g
5.5 cm
8.3 cm
7.8 cm
68 g
United Kingdom
External
Wireless
Data Transfer Rate
300 Mbps
Status Indicators
Power, signal strength, WPS
Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
Internal integrated
Antenna Qty
2
Gain Level
2 dBi
1 x 100Base-TX - RJ-45
1 x network cable
FCC, LVD
Internal power supply
3 Watt
10 - 90% (non-condensing)
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use. Item no in original packaging.
Ref: BW26 035258
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£17.43
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
