BT.com
Wishlist
Zyxel Wireless Mini Travel Router
Delivery
Standard Due date unavailable
Travel Router Optimizes Mobility for Wireless Connection
The sleek, compact ZyXEL NBG2105 Wireless Mini Travel Router brings you an easy way to share Internet access among laptops, smartphones and tablets simultaneously when you're on the road.
Compact design for maximum portability
The ultra-compact design of the ZyXEL NBG2105 provides maximum mobility for business travelers. In hotel rooms with only wired Internet connection, the NBG2105 provides a convenient solution to add wireless connectivity for your Wi-Fi devices such as laptop, smart phone and tablet to get online. It can be powered via USB or the included power supply, and a convenient travel pouch is provided for your convenience.
Simple wireless network setup
The friendly one-touch button design of the ZyXEL NBG2105 provides a simple and easy way for wireless network setup. Through the Clone MAC button and Wi-Fi Protected Setup (WPS) button on the unit, business travelers can easily share registered Internet access among multiple wireless devices securely.
Easy operating mode setup per your needs
The ZyXEL NBG2105 allows you to easily set the operating mode through the Router/Client/WISP with UR mode switch according to your needs for wireless coverage extension or access sharing.
Zyxel NBG2105 - wireless router - 802.11b/g/n - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPPoE, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
NAT support, auto-uplink (auto MDI/MDI-X), MAC address filtering, URL filtering, IP address filtering, Access Point operational mode, USB powered, WISP mode, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS), DHCP server, reset button, Clone MAC button, USB-to-Ethernet mode
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
7.7 cm x 4.3 cm x 1.6 cm
30 g
Europe
2 years warranty
Wireless router
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
150 Mbps
PPPoE, DHCP
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IC, FCC, LVD
Status Indicators
Power, WLAN, LAN, WPS
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 5 pin Micro-USB Type B
Aerial
Aerial
Internal
External power adapter
2 Watt
Carrying case
1 x USB cable
Europe
7.7 cm
4.3 cm
1.6 cm
30 g
10 - 90% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.72
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.36
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.80
£15.07
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.25
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.96
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£40.56
Scroll to top
