BT.com
Wishlist
Zyxel WAC6553D-E 802.11a/b/g/n/ac Radio Access Point
Zyxel WAC6553D-E 802.11a/b/g/n/ac...
£688.83
Hurry, only 1 left in stock!
£688.83
Add to wishlist
Delivery
Standard 1-3 working days
In the Gigabit era in Wi-Fi connectivity, upgrading to the 802.11ac standard represents the next step in wireless evolution. Many enterprises looking to break the 1-Gbps Wi-Fi speed barrier face the challenge of replacing existing 802.11n access points. While 802.11n operates on both 2.4 GHz and 5 GHz frequency band, 802.11ac predominantly uses the 5 GHz band which by its nature traditionally reduces coverage when compared to 2.4 GHz. This led to costly and time consuming efforts for installers to ensure that sufficient APs were installed to give complete coverage.
ZyXEL Smart Antenna technology is a groundbreaking feature of the WAC6500 Series of wireless APs that solves the coverage problem by adaptively adjusting antenna patterns to fit a variety of wireless environments. The Smart Antenna's industry-leading RF output power and sensitivity combine to offer greater coverage and performance over traditional networks, making ZyXEL's WAC6500 Series the ultimate one-to-one AP upgrade choice.
As well as ZyXEL Smart Antenna technology, the WAC6500 Series includes several other features including the innovative APFlexTM, tool-less mounting bracket, and many other software enhancements such as the ZyXEL One Network utilities, making the WAC6500 a complete product designed to streamline network installation and speed deployment for the best possible Wi-Fi experience.
ZyXEL WAC6553D-E - radio access point
Radio access point
External - outdoor
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Throughput: 900 Mbps
Maximum number of configured SSIDs: 16
PoE injector, pole mount, wall mounting kit
Power Over Ethernet (PoE) Supported
PoE+
25.5 cm x 25.6 cm x 6.2 cm
1.708 kg
Radio access point
Ruggedized Design
Outdoor
25.5 cm
25.6 cm
6.2 cm
1.708 kg
Europe
External
Wireless
Data Transfer Rate
1300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall protection, VLAN support, DiffServ support, manageable, MAC address filtering, IPv6 support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Maximum Ratio Combining (MRC), 3T3R MIMO technology, Low Density Parity Check (LDPC), rogue access point detection, plenum-rated, DHCP client, Cyclic Delay Diversity (CDD), Maximum Likelihood Demodulation (MLD), security lock slot (cable lock sold separately), cyclic shift diversity (CSD), ZyXEL One Network (ZON)
Encryption Algorithm
TLS, PEAP, TTLS, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
RADIUS, LDAP, Active Directory
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
6
1 x 1000Base-T (PoE+) - RJ-45 , 1 x console - RJ-45
MTBF
562,413 hours
EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15 C, IEC 60950-1, EN 60950-1, FCC Part 15 E, BSMI CNS 13438, EN 301.893, EN 60601-1-2, IP66, EN 300 328, BSMI CNS 14336-1
PoE+
Power injector
25 Watt
-40 °C
60 °C
10 - 90% (non-condensing)
Scroll to top
