BT.com
Wishlist
Zyxel WAC6103D-I 802.11a/b/g/n/ac Radio Access Point
Zyxel WAC6103D-I 802.11a/b/g/n/ac...
£257.84
10 in stock
£257.84
Add to wishlist
Delivery
Standard 1-3 working days
Enterprise-class 11ac with dual-optimized antenna
The WAC6103D-I is a high-performance 802.11ac three-stream access point offering combined data transfer rates up to 1.75Gbps with a dual-optimized antenna. The adjustable antenna provides superior performance in both ceiling- and wall-mounted deployments. User-friendly features allow for adjustment of antenna patterns via either physical switch or GUI in just seconds. No prior professional knowledge of antenna accessory selection or signal coverage fine-tuning is necessary.
Ultra-slim design blends with modern interiors
The WAC6103D-I expresses stylish functionality through its optimized radiating platform, delivering exceptional performance in only 1.26 inches height (32mm). The WAC6103D-I perfectly blends into any modern office, hotel, classroom, or café.
Perfect choice of medium to high-density environments
Designed with dual-optimized antenna, the WAC6103D-I provides switchable signal patterns to reduce inter-floor interference. In addition, advanced Wi-Fi features such as load balancing and smart-client steering ensure a smooth, consistent, and uninterrupted wireless access experience for all users.
Perfect choice for high-density environments
Easy to deploy in multiple AP environments
WAC6103D-I is extraordinarily easy to install with the ZyXEL APFlex™ feature. While deploying large groups of WAC6103D-I with AP controllers in place, APFlex™ enables streamline and hassle-free installation, simple switching between Managed/Standalone AP modes and automatic integration of APs into the network environment. When operating, DCS (dynamic channel selection) balances the AP channels to reduce signal interference.
Zyxel WAC6103D-I - radio access point
Radio access point
External
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Throughput: 900 Mbps
Maximum number of configured SSIDs: 16
Wall/ceiling mounting plate
Power Over Ethernet (PoE) Supported
PoE+
20.39 cm x 19.17 cm x 3.47 cm
445 g
Radio access point
20.39 cm
19.17 cm
3.47 cm
445 g
Europe
External
Wireless
Data Transfer Rate
1.75 Gbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
Remote Management Protocol
SNMP 3, SNMP 2c, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
LDAP support, VLAN support, DiffServ support, manageable, MAC address filtering, IPv6 support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Maximum Ratio Combining (MRC), 3T3R MIMO technology, Low Density Parity Check (LDPC), rogue access point detection, DHCP client, ceiling mountable, Maximum Likelihood Demodulation (MLD), cyclic shift diversity (CSD), ZyXEL One Network (ZON), SmartConnect Technology, rogue access point containment
Encryption Algorithm
TLS, PEAP, TTLS, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
RADIUS, LDAP, Active Directory
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
1
2 x 1000Base-T (PoE+) - RJ-45 , 1 x console
MTBF
1,005,235 hours
EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15 C, IEC 60950-1, EN 60950-1, FCC Part 15 E, BSMI CNS 13438, EN 301.893, EN 60601-1-2, EN 300 328, BSMI CNS 14336-1
PoE+
12.48 Watt
50 °C
10 - 90% (non-condensing)
Other bundles
£257.84
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£261.32
Scroll to top
