BT.com
Wishlist
Zyxel VMG3925-B10B Dual Band Wireless AC/N VDSL2 Combo
Zyxel VMG3925-B10B Dual Band...
£100.53
£100.53
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL VMG3925-B10B is an advanced wireless AC VDSL2 gateway for high-speed Internet access. In addition, G.vector support allows it to increase bitrates and coverage without altering the infrastructure. The ZyXEL VMG3925-B10B integrates an IEEE 802.11 a/b/g/n/ac access point and a Gigabit Ethernet switch for LAN access. The extreme routing performance enables it to act as a concentrator or power hub to distribute contents among different devices connected to the LAN, wired or wirelessly. The Wi-Fi functions have been specially enhanced to ensure high-quality user experience.
ZyXEL VMG3925-B10B - wireless router - DSL modem - 802.11a/b/g/n/ac - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, VDSL2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
PPPoE, IPoE
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3, policy-based routing (PBR)
Remote Management Protocol
HTTP, HTTPS, CLI, TR-069, TR-098, TR-111
Firewall protection, NAT support, MAC encapsulation routing, NAPT support, DoS attack prevention, packet filtering, DiffServ support, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, DNS proxy, port forwarding, reset button, DHCP relay, 3G/4G USB Dongle Support, DHCP client, Class of Service (CoS)
IEEE 802.1D, IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 2.0, IEEE 802.1ag, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, IEEE 802.11ac
18.3 cm x 15 cm x 2.5 cm
275 g
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
PPPoE, IPoE
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.1D, IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 2.0, IEEE 802.1ag, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, IEEE 802.11ac , EMC, LVD
Status Indicators
Power, WLAN, WAN, LAN, USB, Internet, DSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A, ITU G.993.2, ITU G.998.4, ITU G.993.5
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
5
Gain Level
2 dBi
External power adapter
1 x network cable
18.3 cm
15 cm
2.5 cm
275 g
10 - 90% (non-condensing)
Scroll to top
