BT.com
Wishlist
Zyxel USG60W 10/100/1000, 4x LAN/DMZ, 2x WAN, UTM Bundle
Zyxel USG60W 10/100/1000, 4x...
£496.38
Hurry, only 3 left in stock!
£496.38
Add to wishlist
Delivery
Standard 1-3 working days
The advancements in how people work and collaborate have brought three major challenges to small businesses. With the BYOD trend, small businesses today need to provide more Wi-Fi for an exploding amount of smart devices. The use of cloud-based social and productivity applications not only requires small businesses to be able to control, prioritize and block different applications to stay productive, but also opens doors to web attacks. As threats evolve and these business challenges diversify, IT costs will only continue to grow, which is a real problem for small businesses with limited IT resources.
The ZyXEL USG performance series are all-in-one Next Generation Firewalls (NGFW) specifically designed to fulfill the demands BYOD, malware protection, application regulation, and budget control in small business environments. The built-in wireless AP and WLAN controller offer instant wireless hotspot capability and future WLAN scalability. Comprehensive UTM features and application intelligence technology provides deep, extensive protection, while keeping businesses in control of how Web applications are used. The all-in-one design integrates everything small businesses need, delivering easier, more centralized management and lower total cost of ownership (TCO).
ZyXEL USG60W - UTM Bundle - security appliance
Security appliance
Bundled Services
1 year AV+IDP, AS, CF
Licence Qty
2 SSL VPN users
Rack-mountable
Europe
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall throughput: 1000 Mbps , VPN throughput: 180 Mbps , Intrusion detection and prevention throughput: 120 Mbps , Antivirus throughput: 90 Mbps
User licences: unlimited , Concurrent IPSec VPN tunnels: 20 , Concurrent sessions: 40000 , Concurrent SSL VPN users: 12 , Virtual interfaces (VLANs): 16 , New sessions: 3000 , Manageable access points: 10
27.2 cm x 18.6 cm x 3.6 cm
1.43 kg
5 years warranty
Security appliance
Bundled Services
27.2 cm
18.6 cm
3.6 cm
1.43 kg
Europe
Rack-mountable
Wireless, wired
Network / Transport Protocol
L2TP, IPSec, PPPoE, SMTP, DHCP, POP3, IMAP4
Routing Protocol
OSPF, RIP-1, RIP-2, GRE
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Port status, power, system
Firewall protection, DMZ port, routing, DHCP support, NAT support, VPN support, PAT support, SNAT support, load balancing, LDAP support, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, dynamic DNS server, manageable, stackable, E-mail alert, IPv6 support, antivirus analysis, High Availability, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, anti-spam protection, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SSH support, VPN failover, DHCP server, IPv4 support, 3G USB Dongle Support, DHCP relay, IP-MAC binding, CAPWAP support, DHCP client, dual firmware images, static routing, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), Intrusion Detection and Prevention (IDP), VPN concentrator, VPN load-balancing, VPN auto-reconnection, Single Sign-On (SSO) support
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, X.509, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
4
Gain Level
3 dBi
4 x 1000Base-T - RJ-45 ( LAN / DMZ ) , 2 x 1000Base-T - RJ-45 ( WAN ) , 2 x USB - Type A , 1 x console - DB-9
MTBF
497,644 hours
ICSA IPSec certified, ICSA Firewall certified, ICSA Antivirus
External power adapter
28 Watt
Limited warranty - 5 years
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.86
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.56
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.75
£15.85
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.50
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£21.84
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.51
£42.69
Scroll to top
