BT.com
Wishlist
Zyxel USG110 10/100/1000, 4x LAN/DMZ, 2x WAN, 1xOPT Firewall
Zyxel USG110 10/100/1000, 4x...
£557.82
£557.82
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL USG Advanced Series are Next Generation Firewalls (NGFW) designed to meet the mobility, anti-malware and policy enforcement challenges in SMBs. The integrated WLAN controller offers easy WLAN scalability for the growing demand for Wi-Fi; while WAN and VPN load balancing and failover ensures nonstop business communications. ZyXEL USGs offer industry-leading anti-virus, anti-spam, content filtering and application intelligence technology for effective application optimization and comprehensive network protection.
The ZyXEL USG Advanced Series offers SMBs high network availability for always online communications. It features multi-WAN load balancing and failover, and a comprehensive mobile broadband USB modem support list for WAN backup. On top of that, the series supports IPSec load balancing and failover to provide added resiliency for the most mission-critical VPN deployments.
The ZyXEL USG Advanced Series provides extensive anti-malware protection and effective control of web applications - like Facebook, Google Apps and Netflix - with industry-leading firewall, anti-virus, anti-spam, content filtering, IDP and application intelligence. These security measures are enhanced with SSL inspection, which helps block threats that are hidden in SSL encrypted connections and facilitates deeper policy enforcement.
Zyxel USG110 - UTM Bundle - security appliance
Security appliance
Bundled Services
1 year AV+IDP, AS, CF
Licence Qty
5 SSL VPN users
Rack-mountable
Europe
Performance
Firewall throughput: 1.6 Gbps , VPN throughput: 400 Mbps , Intrusion detection and prevention throughput: 300 Mbps , Antivirus throughput: 250 Mbps
User licences: unlimited , Concurrent IPSec VPN tunnels: 100 , Concurrent sessions: 60000 , Concurrent SSL VPN users: 25 , Virtual interfaces (VLANs): 16 , New sessions: 3500 , Manageable access points: 18
30 cm x 17.8 cm x 4.4 cm
2 kg
5 years warranty
Security appliance
Bundled Services
30 cm
17.8 cm
4.4 cm
2 kg
Europe
Rack-mountable
Wired
Network / Transport Protocol
L2TP, IPSec, PPPoE, SMTP, DHCP, POP3, IMAP4
Routing Protocol
OSPF, RIP-1, RIP-2, GRE
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS, SSH
Performance
Status Indicators
Port status, power, system
Firewall protection, DMZ port, routing, DHCP support, NAT support, VPN support, PAT support, SNAT support, load balancing, LDAP support, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, dynamic DNS server, manageable, stackable, E-mail alert, IPv6 support, antivirus analysis, High Availability, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, anti-spam protection, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SSH support, VPN failover, DHCP server, IPv4 support, 3G USB Dongle Support, DHCP relay, IP-MAC binding, CAPWAP support, DHCP client, dual firmware images, static routing, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), Intrusion Detection and Prevention (IDP), VPN concentrator, VPN load-balancing, VPN auto-reconnection, Single Sign-On (SSO) support
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.1Q, X.509
4 x 1000Base-T - RJ-45 (LAN / DMZ) , 2 x 1000Base-T - RJ-45 (WAN) , 2 x USB - Type A , 1 x console - DB-9 , 1 x 1000Base-T - RJ-45
MTBF
787,109.3 hours
ICSA IPSec certified, ICSA Firewall certified, ICSA Antivirus
External power adapter
37 Watt
Limited warranty - 5 years
Scroll to top
