BT.com
Wishlist
Zyxel UAG4100  Business WLAN w/o printer
Zyxel UAG4100 Business WLAN w/o...
£769.40
Hurry, only 2 left in stock!
£769.40
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL UAG4100 Unified Access Gateway is a next-generation, all-in-one wireless hotspot/access gateway designed to fulfill the hospitality challenges of both today and tomorrow. In addition to account management, billing, and data retention capabilities, the UAG4100 offers premium features - like 802.11 a/b/g/n dual-radio Wi-Fi and a built-in WLAN controller - to deliver better scalability, capacity, and performance to fulfill tomorrow's guest access demands. The built-in WLAN controller can manage up to 16 APs, which makes the UAG4100 ideal for multi-room network deployments in smaller accommodation facilities like small hotels, hostels, or B&Bs (bread and breakfast).
Zyxel UAG4100 - wireless router - 802.11a/b/g/n - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing throughput: 200 Mbps
Concurrent users: 200 (maximum 300) , Maximum number of sessions: 40000 , Manageable access points: 8 (maximum 16) , Maximum number of configured SSIDs: 8
Network / Transport Protocol
PPTP, PPPoE, SMTP, DDNS
Routing Protocol
Static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2c, HTTP, HTTPS, SSH, CLI
NAT support, PAT support, Syslog support, VPN passthrough, WLAN controller mode, RADIUS support, DHCP server, Multiple SSID support, HTTP proxy, DHCP relay, Stateful Packet Inspection Firewall (SPIF), SMTP forwarding, DHCP client, selectable bandwidth, Captive Portal
IEEE 802.1Q, UPnP
27.2 cm x 17.1 cm x 3.6 cm
1.46 kg
Europe
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.1Q, UPnP, BSMI, C-Tick Class B, FCC Part 15 B, EN 60950-1, LVD, EMC Class B
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , Management: 1 x console - 9 pin D-Sub (DB-9)
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
28 Watt
MTBF
497,644 hour(s)
Europe
27.2 cm
17.1 cm
3.6 cm
1.46 kg
10 - 90% (non-condensing)
Accessories
£4.95
£3.84
£11.41
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.16
£51.70
Scroll to top
