BT.com
Wishlist
Zyxel SFP10G-LR 10G Long Range SFP+ Transceiver
Zyxel SFP10G-LR 10G Long Range SFP+...
£139.02
£139.02
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barrier set by proprietary technologies.
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be freely added when required, and infrastructure upgrades or transceiver repairs can be done easily by just replacing the transceiver instead of the whole device.
ZyXEL SFP10G-LR - SFP+ transceiver module - 10 Gigabit Ethernet
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 Gigabit Ethernet
Max Transfer Distance
10 km
1.48 cm x 5.65 cm x 1.185 cm
20 g
5 years warranty
ZyXEL XGS1910-24, XGS1910-48
Plug-in module
Wired
Cabling Type
10GBase-LR
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Hot swap module replacement, Digital Diagnostics Monitoring Interface (DDMI)
1 x Ethernet 10GBase-LR - LC single-mode x 2
Compatible Slots
1 x SFP+
TUV, Laser Class 1, FCC CFR21 Part 1040, FDA, MSA
1.48 cm
5.65 cm
1.185 cm
20 g
Limited warranty - 5 years
70 °C
Accessories
£13.41
£17.41
£22.12
Scroll to top
