BT.com
Wishlist
Zyxel SFP-100LX-20 100 Base FE Fiber Transceiver Module - 20km
Zyxel SFP-100LX-20 100 Base FE...
£115.24
£115.24
Add to wishlist
Delivery
Standard Due date unavailable
ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barriers set by proprietary technologies.
With ZyXEL's comprehensive Fast and Gigabit transceiver product range, users can just plug in the proper model to extend the physical network coverage.
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be added when required, and infrastructure upgrade or transceivers repair can be done easily by just replacing the transceiver instead of the whole device.
Zyxel SFP-100LX-20 - SFP (mini-GBIC) transceiver module - Fast Ethernet
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
100Base-LX10
Data Transfer Rate
125 Mbps
Optical Wave Length
1310 nm
Fast Ethernet
Max Transfer Distance
20 km
5.6 cm x 1.3 cm x 1.2 cm
5 years warranty
Dimension ES-2108-F
Plug-in module
Wired
Cabling Type
100Base-LX10
Fast Ethernet
Data Transfer Rate
125 Mbps
Optical Wave Length
1310 nm
20 km
IEEE 802.3ah
1 x Ethernet 100Base-BX-U - LC x 2
Compatible Slots
1 x SFP (mini-GBIC)
CSA, TUV, Laser Class 1, FCC CFR21 Part 1040
5.6 cm
1.3 cm
1.2 cm
Limited warranty - 5 years
70 °C
5 - 95%
Zyxel Dimension ES-2108-F
Scroll to top
