BT.com
Wishlist
Zyxel SFP-100FX-2 100 Base FX FE Fiber Transceiver Module
Zyxel SFP-100FX-2 100 Base FX FE...
£82.09
£82.09
Add to wishlist
Delivery
Standard Due date unavailable
ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barriers set by proprietary technologies.
With ZyXEL's comprehensive Fast and Gigabit transceiver product range, users can just plug in the proper model to extend the physical network coverage.
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be added when required, and infrastructure upgrade or transceivers repair can be done easily by just replacing the transceiver instead of the whole device.
Zyxel SFP-100FX-2 - SFP (mini-GBIC) transceiver module - Fast Ethernet
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
100Base-FX
Data Transfer Rate
125 Mbps
Optical Wave Length
1310 nm
Fast Ethernet
Max Transfer Distance
2 km
5.6 cm x 1.3 cm x 1.2 cm
5 years warranty
Dimension ES-2108-F
Plug-in module
Wired
Cabling Type
100Base-FX
Fast Ethernet
Data Transfer Rate
125 Mbps
Optical Wave Length
1310 nm
2 km
IEEE 802.3u
1 x Ethernet 100Base-BX-U - LC x 2
Compatible Slots
1 x SFP (mini-GBIC)
CSA, TUV, Laser Class 1, FCC CFR21 Part 1040
5.6 cm
1.3 cm
1.2 cm
Limited warranty - 5 years
70 °C
5 - 95%
Zyxel Dimension ES-2108-F
Scroll to top
