BT.com
Wishlist
Zyxel SBG3600-N Wireless Router DSL Modem 4-port Switch GigE
Zyxel SBG3600-N Wireless Router DSL...
£303.10
£303.10
Add to wishlist
Delivery
Standard Due date unavailable
Networking services are becoming more imperative for small businesses to take advantage of easy communication and effective services. The ZyXEL SBG3600-N series are the "multi-WAN gateway" that provides high-speed Internet access for business users. Featuring VDSL2/ADSL2+ functionality, one GbE WAN with Small Form Pluggable (SFP) interface and a builtin LTE module, these devices offer flexible multiple-WAN connectivity to adopt various Internet interfaces. It also enhances network performance for small businesses to pursue the ultimate success.
Zyxel SBG3600-N - wireless router - DSL modem - 802.11b/g/n - rack-mountable
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Rack-mountable
Digital Signaling Protocol
VDSL, ADSL2, ADSL2+, READSL, VDSL2
Cellular Protocol
LTE
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Performance
Firewall throughput: 800 Mbps , VPN throughput: 40 Mbps
Concurrent IPSec sessions: 20 , Virtual interfaces (VLANs): 16 , Manageable access points: 2 (maximum 10) , Maximum number of configured SSIDs: 4 , NAT sessions: 20000 , ACL rules: 256
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, IPoE, FTP
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, TR-069, TR-098, TR-111
Firewall protection, auto-sensing per device, NAT support, auto-negotiation, SNAT support, auto-uplink (auto MDI/MDI-X), Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, IPv6 support, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), file sharing, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, VPN failover, WAN failover, DHCP server, Multiple SSID support, DNS proxy, DHCP relay, 3G/4G USB Dongle Support, CAPWAP support, DHCP client, Management Information Base (MIB), dual firmware images, Captive Portal, PPTP passthrough, VPN auto-reconnection, VPN fallback, L2TP passthrough, WAN fallback, WAN load balancing, Seamless Rate Adaptation (SRA), ZyXEL Wireless Optimizer (ZWO), ZyXEL AP Controller (APC) Lite, Rom-D support
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n
24.2 cm x 17 cm x 3.6 cm
1.69 kg
Europe
Wireless router - 4-port switch (integrated)
Enclosure Type
Rack-mountable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Performance
MAC Address Table Size
2014 entries
Routing Protocol
RIP-1, RIP-2
Encryption Algorithm
DES, Triple DES, MD5, AES, TLS, SHA-1, TTLS, TKIP, WPA, WPA2, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK
Authentication Method
RADIUS, PAP, CHAP, Radio Service Set ID (SSID), MS-CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 50564:2011, EN 50581:2012, EN 300 328 V1.8.1:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN55022:2010, EN55024:2010, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 50563:2011
Status Indicators
Power, WLAN, WAN, USB, ADSL, SFP
Communications
DSL modem
Cellular Protocol
LTE
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.1, ITU G.993.2, ITU G.992.5 Annex A, ITU G.992.5 Annex B
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , Phone line: 2 x VDSL2 / ADSL2+ - RJ-11 , WAN: 1 x SFP (mini-GBIC)
Aerial
Aerial
External detachable
Gain Level
3 dBi
External power adapter
15.3 Watt
1 x network cable , 1 x modem cable
Rack Mounting Kit
Included
MTBF
300,000 hours
Europe
24.2 cm
17 cm
3.6 cm
1.69 kg
10 - 95% (non-condensing)
Accessories
Network Adaptors
Expand your network
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBC | In Stock
£24.57
Other bundles
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.75
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.32
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.09
£14.71
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.29
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.30
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£31.83
£50.76
Scroll to top
