BT.com
Wishlist
Zyxel SBG3300 Wireless Router DSL Modem 4-port Switch GigE
Zyxel SBG3300 Wireless Router DSL...
£153.63
More than 50 in stock
£153.63
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL SBG3300-N series applies ACL rules, Stateful Packet Inspection (SPI), Denial of Service (DoS) and DDoS features for first-line defense against hackers, network intruders and other harmful threats. A configurable DMZ provides more flexible accessibility while preventing external attacks on confidential databases.
The ZyXEL SBG3300-N series includes multiple WAN interfaces for DSL, Ethernet and USB 3G/4G adapters to establish WAN backups or load balancing. The WAN backup provides contingency in case the primary line or ISP suffers temporary outage. When the primary line of normal services is restored, all traffic resumes normal activity. This function enables highly reliable connectivity and flexibility in multiple applications.
The ZyXEL SBG3300-N series offers a two-level login mechanism to differentiate user segments. The ISP can also define the policies for the limited accounts to easily manage them with the integrated profile database.
Zyxel SBG3300 - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, READSL, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Concurrent IPSec VPN tunnels: 20 , Simultaneous NAT sessions: 16000 , ACL rules: 256
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, IPoE, FTP
Routing Protocol
RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, TR-069
Firewall protection, DMZ port, NAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, MAC address filtering, IPv6 support, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), IPSec passthrough, Wireless Guest Services, VPN failover, WAN failover, DHCP server, Multiple SSID support, hidden SSID, DNS proxy, port forwarding, DHCP relay, 3G/4G USB Dongle Support, DHCP client, NetUSB support, dual firmware images
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
21 cm x 11.5 cm x 3.3 cm
495 g
Europe
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
300 Mbps
MAC Address Table Size
2014 entries
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, TLS, SHA-1, TTLS, TKIP, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
PAP, CHAP, Radio Service Set ID (SSID), MS-CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, FCC Part 15 B, IEC 60950-1, EN 60950-1, VPNC certified
Status Indicators
Power, WLAN, WAN, LAN, USB, ADSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.993.1, ITU G.993.2, ITU G.992.5 Annex A
Max Transfer Rate
100 Mbps
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11
Aerial
Aerial
External detachable
Antenna Qty
2
Gain Level
3 dBi
External power adapter
18 Watt
Europe
21 cm
11.5 cm
3.3 cm
495 g
20 - 95% (non-condensing)
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.63
£50.74
Scroll to top
