BT.com
Wishlist
Zyxel PLA5256 1000Mbps Powerline Pass-Thru Gigabit Ethernet Adapter
Delivery
Standard Due date unavailable
You have a wired network device in another room that needs Internet connection, but you don't want the mess running a long Ethernet cable to it? Grab a ZyXEL PLA5256, 1000 Mbps powerline pass-thru 2-port Gigabit Ethernet adapter. The PLA5256 utilizes the advanced HomePlug AV2 technology that delivers wired speed of up to 1000 Mbps through your power outlets - great for streaming HD video contents or playing intensive multiplayer online games. The PLA5256 features two Ethernet ports, making it perfect for connecting living room network devices such as set top boxes or video game consoles. With the convenient pass-through power outlet design, it doesn't block the existing wall power outlets from other devices that require it.
Zyxel PLA5256 - Starter Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
1000 Mbps
Network / Transport Protocol
CSMA/CA
Routing Protocol
IGMPv2, IGMP, IGMPv3
128-bit encryption, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), reset button
HomePlug AV, HomePlug AV 2.0, IEEE 1901
12.5 cm x 6.5 cm x 4.2 cm
215 g
Microsoft Windows Vista / XP / 7 / 8
United Kingdom
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1000 Mbps
CSMA/CA
Routing Protocol
Encryption Algorithm
128-bit AES
HomePlug AV, HomePlug AV 2.0, IEEE 1901, BSMI, FCC, ICES, LVD
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM, ROBO, 1024 QAM, 4096 QAM
LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x HomePlug AV 2.0
Internal power supply
5.5 Watt
1 x network cable
United Kingdom
12.5 cm
6.5 cm
4.2 cm
215 g
10 - 90% (non-condensing)
Scroll to top
