BT.com
Wishlist
ZyXEL PLA4211 500Mbps Pass-through Powerline Starter Kit
Delivery
Standard Due date unavailable
Kit Contains 2 Units
Read the review on Bit-Tech - Score 86%
Compact Powerline Adapters with Extra Plug Upgrade Your Home Network Conveniently
The ZyXEL PLA4211 500 Mbps Mini Powerline Pass-Thru Ethernet Adapter improves performance for up to 60% comparing to the 200 Mbps powerline technology**. The compact design with extra power outlet gives you the convenience to deploy home networks without the compromises of your existing power outlet. The embedded noise filter of PLA4211 provides more stable multimedia streaming enjoyments by minimizing interference from other home electric devices.
Fast Media Network
ZyXEL PLA4211 500 Mbps Mini Powerline Pass-Thru Ethernet Adapter Starter Kit upgrades home networks with faster wireless speeds of up to 500 Mbps* to provide more stable and reliable connections for web surfing.
Additional Power Outlet
The new, compact ZyXEL PLA4211 gives you the installation flexibility to turn power lines into a home network. You can conveniently deploy the home network and provide power to other electrical devices instantaneously through the extra power outlet. With plug-and-play installation of a pair of PLA4211, you can easily connect your Smart TV, Blu-ray™ players, DVRs, PCs or game consoles to the home network through any electrical outlet.
Ideal for Media Streaming and Gaming
Powered by the IEEE 1901 500 Mbps technology*, the ZyXEL PLA4211 can provide a stable high-performance network for you to enjoy multiple HD streaming, multiplayer gaming and Web surfing simultaneously. The embedded noise filter enables the PLA4211 to suppress noise from all electronic equipment plugged into it and also enhances the network environment for multimedia streaming.
Zyxel PLA4211 - Starter Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV), IEEE 1901
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
128-bit encryption, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Quality of Service (QoS), integrated power socket
HomePlug AV, IEEE 1901
6.4 cm x 3.9 cm x 10.2 cm
184 g
Microsoft Windows Vista / XP / 7
United Kingdom
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
HomePlug AV, IEEE 1901, FCC, RoHS, LVD
Status Indicators
Power, link/activity
1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
Internal power supply
4 Watt
ZyXEL 500 Mbps Mini Powerline Pass-Thru Ethernet Adapter (PLA4211)
1 x network cable
United Kingdom
6.4 cm
3.9 cm
10.2 cm
184 g
10 - 90% (non-condensing)
Accessories
£4.95
£3.82
£11.91
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.50
£54.00
Scroll to top
