BT.com
Wishlist
Zyxel P-793H v2 4-wire SDSL Router 4-port switch
Delivery
Standard Due date unavailable
The ZyXEL P-793H v2 is a high performance SHDSL.bis gateway for small/medium office to have Internet access and LAN-to-LAN application over the existing copper line. The P-793H v2 makes full use of the advanced G.SHDSL.bis technology, its symmetric transmission data rate can be up to 11.4.Mbps.
The P-793H v2 is a G.SHDSL.bis gateway with high flexibility that supports ether ATM mode or EFM mode to provide high-speed LAN-to-LAN connection and Internet access for small business or branch offices through G.SHDSL.bis connection over the copper line. Users can set up a point-to-point connection between two P-793H v2 devices. The feature offers a cost-effective, high-speed connection for high-bandwidth applications such as video conferencing and distance learning.
Zyxel Prestige 793H v2 - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
SHDSL
WAN Ports Qty
1
Ethernet, ATM, Fast Ethernet
Simultaneous NAT sessions: 2048 , Permanent virtual circuits (PVC): 8 , VPN tunnels: 10
Network / Transport Protocol
TCP/IP, UDP/IP, NetBEUI/NetBIOS, ICMP/IP, IPSec, PPPoE, PPPoA, AAL5, IPoA, IPoE, ARP
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, static IP routing
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, CLI, TR-069
Auto-sensing per device, NAT support, VPN support, Syslog support, traffic shaping, DoS attack prevention, content filtering, ALG support, dynamic DNS server, firmware upgradable, LAN-to-LAN bridging, IPSec Virtual Private Network (VPN), event log, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), DHCP server, DNS proxy, port forwarding, DHCP relay, Stateful Packet Inspection Firewall (SPIF), DHCP client
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ah
18.1 cm x 12.8 cm x 3.7 cm
250 g
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, AES, IKE, SHA-1
Authentication Method
PAP, CHAP
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ah, FCC, RoHS
Line Properties
Line Coding Format
TC-PAM
Communications
DSL modem
SHDSL
Protocols & Specifications
ITU G.991.2 (G.shdsl), ITU G.994.1 (G.hs), ITU-T G.998.1, ITU-T G.998.2
Max Transfer Rate
11.4 Mbps
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x SHDSL - RJ-11 , Management: 1 x console - RJ-45
External power adapter
18.1 cm
12.8 cm
3.7 cm
250 g
20 - 90% (non-condensing)
Scroll to top
