BT.com
Wishlist
Zyxel NWD6605-EU0101F AC900 Dual-Band Wireless-AC USB Adapter
Zyxel NWD6605-EU0101F AC900...
£31.14
10 in stock
£31.14
Add to wishlist
Delivery
Standard 3-5 working days
Superior Wireless Connection for HD streaming
The ZyXEL NWD6605 Dual-Band Wireless AC1200 USB Adapter delivers data at up to 300 Mbps* for 2.4 GHz or 867 Mbps* for 5 GHz. It comes with two antennas that enable it to deliver a wider coverage and provide better wireless performance. It's ideal for HD video streaming, online gaming, and multi-thread downloading and sharing multiple large files simultaneously.
Dual-band avoids network clutter and optimizes HD media experience
The ZyXEL NWD6605 provides users the ultimate visual experience over the dual-band network and takes advantage of the common 2.4 GHz band for Web browsing with faster speeds or the interference-free 5 GHz band for smooth HD video playback and online gaming. Dual internal and external antennas reach a wider coverage for good network connection quality even you are a distance away from the wireless router or access point.
USB 3.0 interface for high-speed network experience
With transfer data rates of up to 5 Gigabit per second, the USB 3.0 interface is 10 times faster than USB 2.0. The NWD6605 adopts USB 3.0 interface to realize the true high-speed network experience.
Easy setup with Wi-Fi Protected Setup (WPS)
The friendly one-touch button design provides an easy, intuitive way to setup a secure wireless network. Just press the WPS button to enjoy the protected network in seconds.
Zyxel NWD6605 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
9.5 cm x 2.9 cm x 1.3 cm
20 g
Europe
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
Apple MacOS X 10.6, Apple MacOS X 10.7 Lion, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions), Apple MacOS X 10.8
2 years warranty
Network adapter
External
USB 2.0
Europe
Wireless
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
External integrated and internal
Antenna Qty
2
1 x USB extension cable (external)
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
LVD
1.6 Watt
9.5 cm
2.9 cm
1.3 cm
20 g
10 - 90% (non-condensing)
Scroll to top
