BT.com
Wishlist
Zyxel NWD6505-EU0101F AC450 Dual-Band Wireless-AC USB Adapter
Zyxel NWD6505-EU0101F AC450...
£29.58
4 in stock
£29.58
Add to wishlist
Delivery
Standard 3-5 working days
Upgrade Wireless Performance for Home Connection
The ZyXEL NWD6505 Dual-Band Wireless AC600 USB Adapter delivers data transfer rates of up to 150 Mbps* at 2.4 GHz or 433 Mbps* at 5 GHz. It not only provides high-speed network capability but also works with your existing 802.11 a/b/g/n wireless Routers or Access Points.
Dual-band support for stable wireless networks
The ZyXEL NWD6505 provides selectable dual-band (2.4 GHz or 5 GHz) wireless signals for users to enjoy better network connections. The 5 GHz band is ideal for media-centric applications such as HD video streaming or online gaming, while the 2.4 GHz band is suitable for Internet browsing and VoIP telephony without performance degradation.
Easy security setup
Instant security with WPS allows you to create a secure wireless network with a touch on a single button.
Portability with Elegance
The compact, lightweight design of the ZyXEL NWD6505 offers excellent portability for road warriors and others on the move. Users can easily plug a NWD6505 into a USB port on a desktop or laptop to upgrade the network speed instantly. It includes an USB extension cable that enables the user to position the NWD6505 for maximum connectivity.
ZyXEL NWD6505 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
5.8 cm x 2.1 cm x 1.1 cm
8 g
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac
Data Transfer Rate
600 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
Apple MacOS X 10.6, Apple MacOS X 10.7 Lion, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions), Apple MacOS X 10.8
Microsoft Certification
Compatible with Windows 7
2 years warranty
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
600 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
Antenna Qty
2
1 x USB extension cable ( external )
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
IC, FCC, LVD
1.25 Watt
5.8 cm
2.1 cm
1.1 cm
8 g
10 - 90% (non-condensing)
Scroll to top
