BT.com
Wishlist
ZyXEL NWD2205 Wireless N USB2.0 Adapter
Delivery
Standard Due date unavailable
The compact, lightweight design of NWD2205 offers excellent portability. Users can easily plug NWD2205 to a USB connector on desktop or laptop computers to upgrade the network speed instantly. In addition, with bundled USB cable users can easily adjust the direction of NWD2205.
The ZyXEL NWD2205 USB adapter brings you faster wireless connection. With the data transfer rate of up to 300 Mbps, which is over 5 times faster than the 802.11g standard, the NWD2205 offers you the high-speed connection everywhere under Wi-Fi coverage. It not only provides a high-speed network capability, but also works with your existing 802.11b/g network.
Zyxel NWD2205 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
3.6 cm x 1.8 cm x 0.6 cm
3 g
802.11b, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, USB 1.1, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup
Apple MacOS X 10.4.x, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x
Microsoft Certification
Compatible with Windows 7
3 years warranty
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Mbps
Status Indicators
Link activity
Software access point, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
1 x USB extension cable
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
WHQL, IC, FCC, RoHS
3.6 cm
1.8 cm
0.6 cm
3 g
Limited warranty - 3 years
50 °C
20 - 90% (non-condensing)
Scroll to top
