BT.com
Wishlist
Zyxel NWA5123-NI (8 Pack) no PSU Standalone + Controller Access Point
Zyxel NWA5123-NI (8 Pack) no PSU...
Free delivery
£1,254.03
Free delivery
£1,254.03
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL NWA5123-NI 802.11 a/b/g/n Dual-radio Uniied AP consists of 2.4 GHz and 5 GHz dual-band radio to match the concurrent Wi-Fi services with either frequency. The higher frequency of the 5 GHz band provides a shorter signal range compared to the 2.4 GHz band with the same transmit output power. The NWA5123-NI consist of high 5 GHz transmit output power can boost the 5 GHz signal range, providing signal coverage equal to the 2.4 GHz wireless network. Therefore, the complexity of deployment can be considerably reduced.
ZyXEL NWA5123-NI - radio access point
Radio access point
Packaged Quantity
8 (specifications are for single item)
In-ceiling
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 8
Power Over Ethernet (PoE) Supported
PoE
13 cm x 13 cm x 5.45 cm
250 g
Packaged Quantity
Radio access point
13 cm
13 cm
5.45 cm
250 g
In-ceiling
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
CLI
Frequency Band
2.4 GHz, 5 GHz
VLAN support, manageable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), CAPWAP support, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, plenum-rated, DHCP client, ceiling mountable, Maximum Likelihood Demodulation (MLD)
Encryption Algorithm
TLS, PEAP, TTLS, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
4
Gain Level
5 dBi
1 x 1000Base-T (PoE) - RJ-45
MTBF
781,396 hour(s)
ETSI, BSMI, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15.247, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15 E, BSMI CNS 13438, EN 301.893, EN 60601-1-2, BSMI CNS 14336
PoE
External power adapter
Installed Qty
0
50 °C
10 - 90% (non-condensing)
Scroll to top
