BT.com
Wishlist
Zyxel NWA5123-AC (8 Pack) no PSU Standalone + Controller AP
Zyxel NWA5123-AC (8 Pack) no PSU...
£1,266.88
£1,266.88
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL NWA5120 series 802.11n/ac unified access point is WLAN solution perfect for growing business, hospitality and education environments. With a 2-in-1 standalone/managed AP design, users can initially use it as a standalone AP, and convert it to a controller-managed AP when Wi-Fi demand grows. The series is designed with advanced technology to provide trouble-free wireless quality to lower IT overhead. The embedded antennas and signal output are fine-tuned to provide easy RF planning and maximum signal coverage. It also supports such features as dynamic channel selection, load balancing and preauthentication for superb Wi-Fi experience.
Zyxel NWA5123-AC - radio access point
Radio access point
Packaged Quantity
8 (specifications are for single item)
External
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16
Wall/ceiling mounting plate
Power Over Ethernet (PoE) Supported
PoE
13 cm x 13 cm x 5.47 cm
300 g
Packaged Quantity
Radio access point
13 cm
13 cm
5.47 cm
300 g
Europe
External
Wireless
Data Transfer Rate
1200 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
CLI
Frequency Band
2.4 GHz, 5 GHz
VLAN support, manageable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), CAPWAP support, plenum-rated, DHCP client, ceiling mountable, Maximum Likelihood Demodulation (MLD), ZyXEL One Network (ZON), ZyXEL Wireless Optimizer (ZWO), ZyXEL APFlexT
Encryption Algorithm
TLS, PEAP, TTLS, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T (PoE) - RJ-45
MTBF
1,727,244 hours
BSMI, EN 61000-3-2, EN 61000-3-3, FCC Part 15.247, FCC Part 15 E, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN55022:2010, IEC 60950-1:2005, EN 60601-1-2:2007, EN 301 489-17 V2.1.1 (2009-05), EN 55024:2010, CNS 14336:1999, EN 300 328 V1.7.1 (2006-11), ETSI EN 301 893 V1.5.1, LP0002, ETSI EN 301 489-1 V1.8.1 (2008-11), BSMI CNS 13438(99)
PoE
50 °C
10 - 90% (non-condensing)
Other bundles
Zyxel NWA5123-AC (8 Pack) no PSU Standalone +...
£1,266.88
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.22
£1,270.10
Scroll to top
