BT.com
Wishlist
Zyxel NWA5121-NI Standalone and Controller 802.11bgn Wireless Access Point
Zyxel NWA5121-NI Standalone and...
£89.76
£89.76
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL NWA5121 802.11 a/b/g/n Unified Access Point is a highly future-proof WLAN solution perfect for growing business, hospitality and education environments. With a 2-in-1 standalone/managed AP design, users can initially use it as a standalone AP, and convert it to a controller-managed AP when Wi-Fi demand grows. It is designed with industry-leading technology to provide trouble-free wireless quality to lower IT overhead. The embedded antennas and signal output are fine-tuned to provide easy RF planning and maximum signal coverage. It also supports such features as dynamic channel selection, load balancing and pre-authentication for seamless roaming and a superb Wi-Fi experience.
802.11 b/g/n Unified Access Point
  • Ceiling and wall mountable
  • Plenum rated housing
  • 2-in-1 standalone/managed AP design
  • CAPWAP management supported
  • High-performance RF technology: Tx Beamforming and Rx Maximum Likelihood Demodulation (MLD)
ZyXEL NWA5121-NI v2 - radio access point
Radio access point
External
Europe
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Maximum number of configured SSIDs: 8
Power Over Ethernet (PoE) Supported
PoE
13 cm x 13 cm x 5.45 cm
230 g
Radio access point
13 cm
13 cm
5.45 cm
230 g
Europe
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
CLI
Frequency Band
2.4 GHz
VLAN support, manageable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), CAPWAP support, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, plenum-rated, DHCP client, ceiling mountable, Maximum Likelihood Demodulation (MLD)
Encryption Algorithm
TLS, PEAP, TTLS, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
7 dBi
1 x 1000Base-T (PoE) - RJ-45
MTBF
627,152 hours
ETSI, BSMI, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EN 301.489.1, EN 301.489.17, FCC Part 15.247, FCC, IEC 60950-1, EN 60950-1, FCC Part 15.107, BSMI CNS 13438, BSMI CNS 14336, IEC 60601-1-2:2007, EN 300 328 V1.7.1
PoE
External power adapter
4 Watt
50 °C
10 - 90% (non-condensing)
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
