BT.com
Wishlist
Zyxel NBG6815 Dual-Band Wireless AC2200 MU-MIMO Router
Zyxel NBG6815 Dual-Band Wireless...
£139.50
Hurry, only 3 left in stock!
£139.50
Add to wishlist
Delivery
Standard 1-3 working days
The NBG6815 is ZyXEL’s first Multi User MIMO (MU-MIMO) home router that fits into any home interior design with its chic look, while also upgrading home networks with MU-MIMO technology. It also supports a Gigabit-class wired connection, wireless speeds of up to 2200 Mbps, and two USB ports. The NBG6815 provides the perfect hub for home entertainment: users can share photos, music, and videos smoothly on their home network, and also inspect or manage the network easily through the ZyXEL ONE Connect APP and Usage Monitor.
ZyXEL NBG6815 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, SMB, DDNS
Routing Protocol
IGMPv2, IGMP, static IP routing
Firewall protection, NAT support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, print server, MAC address filtering, IPv6 support, VPN passthrough, parental control, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS), DHCP server, reset button, DLNA Media Server, DHCP client, Denial of Service (DoS), StreamBoost, MU-MIMO technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, IEEE 802.11ac
26.04 cm x 18.2 cm x 8.12 cm
578 g
Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Routing Protocol
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, IEEE 802.11ac , FCC, LVD
1 x 700 MHz
RAM
256 MB
Status Indicators
Power, system, WLAN, WAN, WPS, Internet
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x
Aerial
Aerial
Internal
External power adapter
30 Watt
1 x network cable
Europe
26.04 cm
18.2 cm
8.12 cm
578 g
10 - 90% (non-condensing)
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
