Click to visit BT.com
BT.com
Wishlist
Zyxel NBG5715 Simultaneous Dual-Band Wireless N Media Router
Quicklinx: 81MRWS00
Mfr#: NBG5715-EU01F
With three dual-band antennas featuring MIMO technology, the NBG5715 provides you the ultimate visual experiences over the true dual networks at blazing data transfer rates. You can simultaneously surf the web over the common 2.4 GHz band with fast speeds and watch HD video or play online games over the interference-free 5 GHz band with smooth playback.
Thanks to the SamrtRange technology, the NBG5715 provides effective wireless coverage by transmitting wireless signals directly to other wireless network devices such as tablet PCs, laptops and game consoles. You can enjoy digital entertainment content without dead spots in every room at home.
ZyXEL NBG-5715 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
IPSec VPN tunnels : 5 , Simultaneous NAT sessions : 16000
Network / Transport Protocol
PPTP, L2TP, IPSec, DHCP
Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, MAC address filtering, VPN passthrough, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, DNS proxy, NTP server, DHCP client, NetUSB support
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
21.4 cm x 7.4 cm x 16.5 cm
490 g
Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup, UPnP , EMC, FCC, RoHS, WEEE
Status Indicators
Power, WAN, LAN, wireless, USB
LAN : 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN : 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB : 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Gain Level
2 dBi
External power adapter
21 Watt
1 x network cable
Europe
Software Included
Drivers & Utilities
21.4 cm
7.4 cm
16.5 cm
490 g
20 - 90% (non-condensing)
