BT.com
Wishlist
Zyxel NBG-418Nv2 Wireless N300 Home Router
Delivery
Standard Due date unavailable
The ZyXEL NBG-418N Wireless N home router provides more stable and reliable wireless connections for web surfing, Internet sharing and multimedia streaming. Better yet, its rich green features will bring you an energy-saving wireless network without compromising performance.
Zyxel NBG-418N - v2 - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), repeating mode, DoS attack prevention, dynamic DNS server, MAC address filtering, IPv6 support, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS), DHCP server, reset button, bandwidth control, DHCP client
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
14.2 cm x 10.2 cm x 2.3 cm
148 g
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, BSMI, FCC, RoHS, LVD
Status Indicators
Power, WLAN, WAN, WPS
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
3.5 Watt
1 x network cable
United Kingdom
14.2 cm
10.2 cm
2.3 cm
148 g
10 - 90% (non-condensing)
Scroll to top
