BT.com
Wishlist
Zyxel MS7206S 6 Slot Chassis Switch Fibre Bundle
Zyxel MS7206S 6 Slot Chassis Switch...
Free delivery
£3,992.17
Free delivery
£3,992.17
Add to wishlist
Delivery
Standard Due date unavailable
If ZyXEL's MS-7206S was a person, it would have quite the hat collection. The MS-7206S, due to its power and modularity, is a switch that can be used in a lot of different roles. It can be a SMB core switch, a distribution switch for Enterprise and Campus deployments, an intelligent switch for Enterprise, or an aggregation switch for data centers and telcos.
This modular switch offers intelligent L2/L3/L4 local switching and advanced management features. It's ideal for large business and campus networks.
ZyXEL MS-7206S PoE Bundle - switch - 48 ports - Managed - desktop
Switch - 48 ports - L4 - Managed
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE)
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, static IP routing, IGMPv3
Remote Management Protocol
RMON 1, RMON 2, SNMP, RMON 3, RMON 9, SNMP 2c, HTTP
Flow control, modular design, hot swap module replacement, Layer 4 switching, Layer 3 switching, Layer 2 switching, power over Ethernet (PoE), auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, manageable, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), Access Control List (ACL) support, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
AC 120/230 V ( 50/60 Hz )
43.5 cm x 31.6 cm x 44.7 cm
15.5 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2)
Status Indicators
Power, system, status
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 - PoE , 1 x 10Base-T/100Base-TX - RJ-45 - management , 1 x RS-232 - 9 pin D-Sub (DB-9) - management , Accessory: 1 x RS-232 - 9 pin D-Sub (DB-9)
Expansion Slots
6 (total) / 3 (free) x Expansion Slot
Installed Modules Qty (Max)
3 (installed) / 6 (max)
Internal power supply
Installed Qty
2 (installed) / 2 (max)
600 Watt
43.5 cm
31.6 cm
44.7 cm
15.5 kg
Scroll to top
