BT.com
Wishlist
Zyxel MI7526F 10G Module 24xSFP slots + 10G Module slot
Zyxel MI7526F 10G Module 24xSFP...
£2,376.02
£2,376.02
Add to wishlist
Delivery
Standard Due date unavailable
The MI-7526F is a Gigabit Ethernet interface module that has 20 mini-GBIC (SFP) slots and four dual personality interfaces. It also has one slot for a 10 Gigabit uplink module.
Zyxel MI-7526F - expansion module
Expansion module
Plug-in module
Ports
Gigabit Ethernet x 4
39.7 cm x 27.6 cm x 4.3 cm
2.1 kg
Auxiliary Ports
4 x shared Ethernet 1000Base-T
GigE
Data Transfer Rate
1 Gbps
Expansion module
Plug-in module
Ports
Wired
GigE
Auxiliary Ports
Data Transfer Rate
1 Gbps
Status Indicators
Power, active, status
Expansion Slots
24 x SFP , 1 x expansion slot
4 x 1000Base-T - RJ-45
Compatible Slots
1 x Expansion Slot
CSA, EMC, FCC, UL 60950-1, IEC 60950-1, EN 60950-1
39.7 cm
27.6 cm
4.3 cm
2.1 kg
45 °C
10 - 90%
Scroll to top
