BT.com
Wishlist
Zyxel MGS3520-28F 28 Port Metro Switch 24x SFP 4x Combo AC
Zyxel MGS3520-28F 28 Port Metro...
£493.59
£493.59
Add to wishlist
Delivery
Standard Due date unavailable
The MGS3520 Series GbE L2 Managed Switch is specially designed for service providers to deliver profitable Ethernet services. With the high-performance hardware platform, service providers can easily extend network topologies while enabling robust security, QoS and management functions to help customers fulfilling differentiated needs for Metro Ethernet services.
Zyxel MGS3520-28F - switch - 24 ports - Managed
Switch - 24 ports - Managed
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP + 4 x combo Gigabit SFP
Performance
Switching capacity: 48 Gbps , Forwarding performance: 35.7 Mpps
QoS hardware queues per port: 8
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, TFTP, CLI
Flow control, IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, VLAN Stacking, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, NTP server, IP-MAC binding, DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), Multicast VLAN Registration (MVR), Strict Priority Queuing (SPQ), port isolation, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), 1.5MB packet buffer, CPU protection, ARP inspection
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.3az
AC 120/230 V / DC 12 V
44 cm x 27 cm x 4.45 cm
Europe
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
4 x 1000Base-T - RJ-45 , 28 x - SFP , 1 x management - DB-9
Internal power supply
ICES-003, FCC Part 15 B, RoHS, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:2010, EN 61000-3-3:2013, AS/NZS CISPR22:2009+A1:2010, EN 55022:2010/AC:2011, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+AC:2013
Europe
44 cm
27 cm
4.45 cm
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Other bundles
Zyxel MGS3520-28F 28 Port Metro Switch 24x SFP 4x Combo...
£493.59
Save on TP Link Smart Plug
Save £2.00
£517.56
Scroll to top
