BT.com
Wishlist
Zyxel MES-3728 24-port 10/100 L2 Metro Switch
Zyxel MES-3728 24-port 10/100 L2...
£573.74
£573.74
Add to wishlist
Delivery
Standard Due date unavailable
The MES-3728's high-performance hardware platform and physical features enable service providers to easily extend network topologies, while the robust security and management functions help customers to fulfill differentiated metro Ethernet service needs. The MES-3728 not only represents ZyXEL's entry into the metropolitan Ethernet networking arena, but also demonstrates the company's technical capability on metro Ethernet deployments.
Zyxel MES-3728 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x SFP + 2 x combo Gigabit SFP
Performance
Switching capacity: 12.8 Gbps , Forwarding performance: 9.6 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c
ARP support, VLAN support, IGMP snooping, MAC address filtering, firmware upgradable, Weighted Fair Queuing (WFQ), DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), temperature / humidity sensor, DHCP relay, IP-MAC binding
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag
AC 120/230 V / DC -48 -60 V (50/60 Hz)
43.8 cm x 22.5 cm x 4.5 cm
3.4 kg
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
24 x 10Base-T/100Base-TX - RJ-45 , 2 x 1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x serial (RS-232) , 1 x console - RJ-45
Internal power supply
MTBF
307,007 hours
RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
43.8 cm
22.5 cm
4.5 cm
3.4 kg
65 °C
10 - 99% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Scroll to top
