BT.com
Wishlist
Zyxel MES-3528 24 port 10/100 L2 Metro Switch
Zyxel MES-3528 24 port 10/100 L2...
£225.90
£225.90
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL MES-3528 is specially designed for service providers to deliver profitable Ethernet services. With the high-performance hardware platform, service providers can easily extend network topologies while enabling robust security, QoS and management functions to help customers fulfilling differentiated needs for Metro Ethernet services.
Consistent service quality and reliable connecting ability in a converged network is the key for service providers to win customers and build loyalty; therefore the ability to control traffic flow and set traffic policy becomes more critical than ever. The ZyXEL MES-3528 offers wire-speed flow control that classifies and prioritizes the incoming packets according to the predefine QoS policies that meet requirements of service providers. In terms of classification, the Differentiated Services Code Point (DSCP) field and the 802.1p class of service (CoS) field are identified to assess the priority of incoming packets. Classification and reclassification can be based on criteria as specific as rules based on IP, MAC addresses, VLAN ID or TCP/UDP port number. For bandwidth management, the MES-3528 provides 8 priority queues per port for different types of traffics, allowing service providers to set rule-based rate limitations that take full advantage of constrained network resources and guarantee the best performance.
Avoiding subscribers affecting each other on a shared network or shared device is a major concern for service providers. The ZyXEL MES-3528 offers a complete set of security features to protect user data while administrating the traffics. Port security provides the ability to deny unauthorized users from accessing the network. Moreover, the 802.1x feature cooperating with RADIUS is useful to prevent unauthorized access based on username and password (or other credentials) and acts as powerful access control for converged networks with mixed wired and wireless access. The MES-3528 provides a multilayer (L2/L3/L4) ACL suite of sophisticated policy-based control mechanisms that enables service providers to deploy easily based on actual network environment needs via a Web GUI or command line interface to prevent abnormal or illegal access. The policies can be defined to deny packets based on source and destination MAC addresses IP addresses or TCP/UDP ports.
Zyxel MES-3528 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 4 x combo Gigabit SFP
Performance
Switching capacity: 12.8 Gbps , Forwarding performance: 9.6 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
9000 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2
Flow control, DHCP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, packet filtering, port mirroring, DiffServ support, manageable, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IP address filtering, firmware upgradable, Weighted Fair Queuing (WFQ), Digital Diagnostics Monitoring Interface (DDMI), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, VLAN Stacking, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag
AC 120/230 V / DC 48/60 V
43.8 cm x 17.5 cm x 4.5 cm
2.8 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9000 bytes
Max Units In A Stack
24
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Link activity, power, link OK, system, alarm
24 x 10Base-T/100Base-TX - RJ-45 , 1 x serial (RS-232) - DB-9 , 4 x SFP (mini-GBIC) , 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
20 Watt
FCC Class A certified, CSA, UL
43.8 cm
17.5 cm
4.5 cm
2.8 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
£50.74
Scroll to top
