BT.com
Wishlist
Zyxel MES-3500 24-port Fast Ethernet Managed L2 Switch
Zyxel MES-3500 24-port Fast...
£439.96
£439.96
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL MES3500-24 has been specially designed for service providers to deliver profitable Ethernet services. With the high-performance hardware platform, service providers can easily extend network topologies while enabling robust security, QoS and management functions to help customers fulfilling different needs and to support the IPv6 for trouble-free future network expansions.
ZyXEL MES3500-24 - switch - 24 ports - Managed - desktop, rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Desktop, rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100 + 4 x combo Gigabit SFP
Performance
Switching capacity: 12.8 Gbps , Forwarding performance: 9.6 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Flow control, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, firmware upgradable, Weighted Fair Queuing (WFQ), Digital Diagnostics Monitoring Interface (DDMI), ZyXEL iStacking Technology, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, VLAN Stacking, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, bandwidth control, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, IP-MAC binding, DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), Multicast VLAN Registration (MVR), Dynamic VLAN Support (GVRP), Strict Priority Queuing (SPQ), loop prevention, port isolation, tagged VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.3az
AC 120/230 V / DC -37 -72 V
44 cm x 20 cm x 4.45 cm
2.6 kg
United Kingdom
Enclosure Type
Subtype
Fast Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Max Units In A Stack
24
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
320 KB
Status Indicators
Port status, power, system, alarm, link/activity
24 x 10Base-T/100Base-TX - RJ-45 , 1 x serial (RS-232) - DB-9 , 4 x SFP (mini-GBIC) , 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x alarm - terminal block
Internal power supply
14 Watt
BSMI, FCC, RoHS, IEC 60950-1, EN 60950-1
United Kingdom
44 cm
20 cm
4.45 cm
2.6 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
