BT.com
Wishlist
Zyxel MES-3500-10 10 Port 10/100 L2 Metro Switch
Zyxel MES-3500-10 10 Port 10/100 L2...
£140.19
£140.19
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL MES3500 series has been specially designed for service providers to deliver profitable Ethernet services. With the high-performance hardware platform, service providers can easily extend network topologies while enabling robust security, QoS and management functions to help customers fulfilling different needs and to support the IPv6 for trouble-free future network expansions.
Zyxel MES3500-10 - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8 x 10/100 + 2 x combo Gigabit SFP
Performance
Switching capacity: 5.6 Gbps , Forwarding performance: 4.2 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Flow control, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, firmware upgradable, Weighted Fair Queuing (WFQ), Digital Diagnostics Monitoring Interface (DDMI), ZyXEL iStacking Technology, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, VLAN Stacking, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, bandwidth control, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, IP-MAC binding, DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), Multicast VLAN Registration (MVR), Dynamic VLAN Support (GVRP), Strict Priority Queuing (SPQ), loop prevention, port isolation, tagged VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.3az
AC 120/230 V
26.5 cm x 18.37 cm x 4.4 cm
1.37 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable
Subtype
Fast Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Max Units In A Stack
24
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Port status, power, system, alarm, link/activity
8 x 100Base-TX - RJ-45 , 1 x serial (RS-232) - DB-9 , 2 x - SFP , 2 x 1000Base-T - RJ-45
Internal power supply
AC 120/230 V
12 Watt
FCC, RoHS, IEC 60950-1, EN 60950-1
United Kingdom
26.5 cm
18.37 cm
4.4 cm
1.37 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Scroll to top
